Strain values
Is there any way to see the strain values in Autopipe results grid? Or any results report? If not, how should I calculate the combined strain values?
Arash
  • Greetings Arash,
    To answer your questions:
    Q1. Is there any way to see the strain values in Autopipe results grid?
    Answer:
    As of AutoPIPE v12.08.00.063, unfortunately there is no feature to display the Strain.
    Q2. Or any results report?
    Answer:
    As of AutoPIPE v12.08.00.063, unfortunately there is no feature to report the Strain.
    Q3. If not, how should I calculate the combined strain values?
    Answer:
    Please take a moment to clearly define combine strain values?
    I would be guessing, are you speaking about the strain on a pipe that has moved in 3 directions X, Y, and Z? or other? Please be specific.
    Mike Dattilio
    Design Analysis Engineering Group
    Senior Analyst Bentley Systems Inc
