Hello I have a simples piping system with 1 standard tee fitting, upon analysing I get the following warning messages.
* * * W A R N I N G - MODEL * * * W2164-192:B31 App J: Collinearity detected on the following tee(s) and will be analyzed as a non-B31J component: A02
* * * W A R N I N G - MODEL * * * W2164-194:B31 App J: The branch pipe axis is not within 5 degrees normal to the axis of the run pipe for the following tees: A02
Can someone please explain why these warnings come up and how to fix them?
Thank you
Greetings,
Please see WIKI here.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
