The header in the boiler always has more than10 tubes connected to it at one point,but now the autopipe just can create one node at one node.So how to creat more than10 tubes at one node?Or how to calculate the Panel stress for the boiler.
Greetings,
Your last response was missing images. Please send the images again.
In the meantime, to help answer your questions:
Answer Verified By: Mike Dattilio
Please post this as a separate question/ discussion on the forum.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: Boiler Header stress calculation problem
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.Flag this post as spam/abuse.
Greetings Shen Yq,
In order to keep topics relevant, best to logged separate postings for each question. I see 2 different questions from your last postings.
1. Model a safety valve
2. Model a bend
After you post these new question, someone from the community or I will add an answer.
