Deleting single support at a node with multiple supports
If I have multiple supports at one node, I can delete just one of the supports. However, when I try to select multiple supports viea either on screen, the selection filter or the input grid, it deletes all supports at that node. Even if they are not selected. Is this a bug?
Thanks!
  • Greetings,
    Yes, this is a known issue that has been logged (867597) and will be fixed in a future version of the program.
    Only workaround at this time is to select and delete each support one at a time. Not ideal but will do the job.
    Mike Dattilio
    Design Analysis Engineering Group
    Senior Analyst Bentley Systems Inc
    Answer Verified By: Mike Dattilio
