Hi dear,
After running the analysis, I am receiving the warning W2216-201: operating pressure & temperature data has been updated for following points.
Then some temperature and pressures are updating automatically which I don't want. i want to keep the assigned temperature and pressure. what is the reason for this warning and how I can resolve it?
Thank you
Greetings,
Please provide exact steps to repeat using AutoPIPE example model walkthru.apc.
What are you doing to the model when this message appears?
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
