I am updating the temperatures and pressures throughout the model and found that some points on other segments are also being changed. For example, when changing a singular point, K04, to T1=700F, it is also changing points AR00 to AR02 to 700F as well. It also seems to have the same issue when changing any pressures. I've tried renumbering the points, reordering the segments, restarting AutoPIPE, restarting the computer, and even copying the segment, AR, deleting it, and re-adding it only to have the issue jump to another area in the model. I've opened the model on a co-workers computer and confirmed they are seeing the same issue. It seems to only be affecting this model, as I could not recreate the problem on other models.
AP Version 12.07.00.346
I've added a couple screenshots showing the issue I am running into. The first photo shows the temperatures prior to changing the input (Point K04 circled in red, AR00 in blue) and the second shows the temperatures after only changing point K04 to 700F.
Here is a video of the issue:
Greetings,
The development team has figured out what this issue is occurring (891921) and will be issuing a patch update fairly soon. Please keep an eye on Connection Client update and AutoPIPE Announcements Forum for any updated information.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Answer Verified By: Mike Dattilio
