Hello guys, i have some question, i have piping system that ASTM A335 P22 for material, and it can be operate at 1305 Psi and 789 Fahrenheit in pressure and temperature design. can you show me about the calculation formula that i have reached to solve this. BTW its a pipe for Powerplant. because my own calculation its not same with autopipe result. thankyout, appreciate it.
Greetings,
Check to be sure that none of your Result model option settings or Edit model option settings are affecting the allowable calculation.
If they are not, than answer these questions:
What piping code and year are you using?
What category of calculations are considering?
What equations are you using?
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
