I am using Autopipe connect v12, but do not appear to have the excel templates for importing coordinates. I have tried duplicating the template based on the tutorial but am receiving errors. Is there a copy of these templates available online?
Greetings,
No there is no files on line. If you have AutoPIPE installed on your computer, see WIKI here for file location. As mentioned for Documents, Report templates, Tutorials see the following folder:
Use the correct template as needed:
Always best to make a back up copy of these files for future use. Only other way of getting the original files, reinstall the application.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Answer Verified By: Mike Dattilio
Oh great, thanks for that. I searched for the App and looked through that folder rather than navigating to above directory.
Cheers,
Jeff
