I have piping going thru roof of a building and exposed to wind. My roof elevation is 90'-0". In wind profile screen I am putting ground elevation at 90'-0". (it is done not to expose the pipe to wind below 90'-0"). However, my question is whether AutoPIPE correctly calculates the wind pressure as it is dependent on elevation. The concern is if my piping is at 100' elevation and since I put ground elevation as 90', does it take 10' as the elevation for calculating the wind pressure?
The question is if AutoPIPE takes 10' as the height for calculating the wind pressure?
Greetings,
To add a little more information to Bilal's comments above. Please see the following wiki here.
To be clear, suggest that you enter the correct ground elevation relative to your model (See Point Tab on input grids, node point at roof elevation, vertical location subtract 90'-0". Next, select the roof node point, and split the segment. Finally, on he segment tab enable wind only for those segments that actually have wind applied.
Following these suggests, the program knows exactly where the ground elevation is located in your model, pipe segments inside the building are protected from Wind, and the correct wind load is applied to the pipe xxx distance above the ground.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
