print loads for selected supports
I want to print support loads at selected supports only.  How do I do that using results grid?
  • Greetings,
    The output grids includes results for all supports and all combinations that are set to Print. In order to see results on a select few supports, suggest the following:
    1. Select the supports so that they turn red in the model, generate an output report, with Supports sub report, and Limit reports to highlighted points option enabled.
    or
    2. With the Support tab selected in the Results grids, copy the entire table out to Excel, then use filter data to filter the supports and load cases as needed.
    Mike Dattilio
    Design Analysis Engineering Group
    Senior Analyst Bentley Systems Inc
Reply
  • Greetings,
    or
    Mike Dattilio
