Dear sir,
Sir if it is possible to analysis:
1. Flow induced vibration
2. Acoustic induced vibration
in AutoPIPE. If this method cannot able to perform this methods, Kindly suggest me any alternative method for this analysis.
Dear Sir,
Kindly help me with the above query.
Greetings,
Flow induced vibration analysis and Acoustic Induced vibration can be performed if we get the harmonic loads generated from unbalanced rotating equipment, acoustic vibrations caused by reciprocating equipment, flow impedance, and other sources which can be calculated by using any acoustic simulation program. These harmonic loads can be entered into AutoPipe to perform the Harmonic load analysis.
Shrey Sharma
Technical Support Engineer,Global Technical Support,
Bentley Systems,Inc.
Answer Verified By: Shrey Sharma
