Is it possible to have maximum stress for each type of stress in report?
like one number for SUS one number for EXP ,...
Greetings,
Yes, only limit is that 1 combination can have 10 load cases assigned to it. So if you have 50 load cases for Sus, create 5 combinations with 1-9, 10-19, etc.. and then one additional combination that finds the maximum of the 5 combination that individually find the maximum of a set of 10 combination.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Answer Verified By: Mike Dattilio
