What are required user rights to run AutoPIPE on the specific computer? Is it required to be local Administrator?
We encountered some problems with specific functionality (no matter what functionality) and the problem disappeared after switching user rights to Administrator.
Thank you in advance,
Maciej
Greetings,
As of April 2023, the users' rights required to run AutoPIPE have not changed, they remain the same as always for AutoPIPE Connect version 12.0 to now.
Please review WIKI page here, click hyperlink for "Minimum user permissions required for folders and files".
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Mike,
Thank you. Would you please update it with information regarding StressISO?
While running the program with non-Admin rights on a local machine it seems to be not working quite as expected. Program kind of hangs i.e. does not start generating iso.
Best and thanks,
Best regards,
Maciej Rydlewicz, PhD Eng.
maciej.rydlewicz@softdesk.pl
+48 512206994
