I want to change a constant spring for 2 variable springs, but when I change the number of hanger into the support input, and after I run the hanger selection procedure, Autopipe changes again the variable springs to a TWO constants supports and when I see the hanger report the constant support is there, the hot load is half, but I can't see what is the variable springs type that Autopipe selected, so, the questions are:
Does Autopipe select 2 spring variables springs or not?
Where can I check what support type Autopipe selected?
Edgar,
Sometimes AutoPIPE's procedure (based on industry-standard procedure, which has been defined years ago for manual calculations), does not what you expect. First of all, it looks like the thermal movement of the pipe node is quite high and loading very low in cold conditions. Besides, it probably cannot find a spring (or 2 springs) in the selected manufacturer's catalogue, so it proposes a constant hanger, as he recognizes high thermal movement.
I'd advise moving the hanger's assembly up right or try a manual procedure. Eventually, you inserted this spring assembly to minimize nozzle load - so verify what results you get and change spring settings until you get satisfactory results. It is what I do. Before you start looking for a solution uncheck the "undesigned" checkbox. After you find it also uncheck it.
Best regards,
Maciej Rydlewicz, PhD Eng.
maciej.rydlewicz@softdesk.pl
+48 512206994
