Hello everyone,
I have set the soil model in the following picture.
In the result, When the longitudinal displacement of pipe is greater than yield displacement (592.25 mm), I expect to see 573.3 N/m of soil load in longitudinal axis.
However, the result shows 656 N/m. I'm not sure what model wrong. In additon, the horizontal will happen the same situation when the pipe displacement is greater than yield displacement. (I have not captured for horizontal case)
I notice that my most most models happens the same situation. The maximum soil resistance is a bit greater than what I set in the soil input.
Thank in advance
Greetings,
This is difficult to investigate from these inputs. Best if you please log a new Bentley Case and be sure to attach your AutoPIPE APC file.
Shrey Sharma
Technical Support Engineer,Global Technical Support,
Bentley Systems,Inc.
9th Floor, Tower C, DLF IT Park, 8 Major Arterial Road, Newtown, Kolkata – 700156
T: + 91-2066021018
www.bentley.com
