Stop generating output report
Version : V12.08.04.009
When I generate Excel Reports in Report Manager, generating process is stopped while 'Preparing Compliance report' stage. I deleted and reinstalled the AutoPIPE same version, same issue is still occurred.
All icons in Report Manager have same issue.
How to solve it?
  • Greetings,
    When a model  has many node points or settings generate a lot of printed data, it can take some time to process some commands in AutoPIPE.
    I would suggest following:
    1. Confirm that the number of node points in the model is less than 10,000 points.
    2. If yes, can you generate a Quick Report - output. Recommend, including only a few sub-reports at first, and then adding a few more until the entire report is generated. There maybe one sub-report that is excessively large or causing the issue.
    3. If nothing else helps, try round tripping the model to see if this helps.
    Last option, file a new case for Bentley technical support review. Be sure to send your AutoPIPE APC file for review.
    Mike Dattilio
    Design Analysis Engineering Group
    Senior Analyst Bentley Systems Inc
