Am I able to use B31J when selecting B31.4 Offshore as the design code?
Greetings,
Answer: No
Please refer to ASME B31.4 2019 offshore code compliance information, there is nowhere mentioned to use of B31J Code for SIF calculations. See Also, you can pitch an idea on AutoPipe Idea page for adding the B31J in ASME B31.4 Offshore code. Depending on responses we receive on that idea, we will incorporate that function.
Shrey Sharma
Technical Support Engineer, Global Technical Support,
Bentley Systems
