how to access beam/frame force/moment results?
In an Autopipe model with beam/frame members, how are the force/moment results obtained?
  • You can view the beam forces/moments using Result/output report and check the box for beam forces.
    You can refer to the online help section Help/Contents/Reference Information/Results Interpretation/Frame member forces for more information.
    Frame member results always follow the Local system as described in the online help above, regardless of the result option selected. E.g. i-j is always the x-axis.
