What is the effect of different valve type (e.g. GATE-B vs GLOBE-B vs SCHECK-B vs TCHECK-B) in terms of displacement and stress analysis? What are the difference in the way that the calculation is performed?
Also, I'm using a butt-welded ball valve (designed for subsea purpose) in my analysis but it's not available for selection (the only ball valve is the BALLSE-F). Shall I just specify it as NS?
I'm using AutoPipe version 09.04.01.05.
Thanks in advance for the clarification.
Morgan.
Hello Morgan,
Behind the graphics a valve is really just a rigid pipe that has additional attributes (so to speak). If you open the valve dialog screen, you can see all the fields of data required by a valve component. The most import aspects of a valve "TYPE" and "Pressure rating" is for a look up in the valve library to retrieve predetermine data: Length, Weight, Surface Area Factor, and Joint end Type. The Valve type has no other functionality in the calculations. for your scenario specify a valve Type = NS and adjust the rest of the valve dialog as required.
Thank you for choosing Bentley Systems, Inc
Mike DattilioBentley TSG Analyst
AutoPIPE On demand eSeminars for AutoPIPE V8iwww.bentley.com/.../eSeminars.htm
New feature for AutoPIPE 9.4 and STAAD PRO/Foundations V8i SS3:ftp.bentley.com/.../AutoPIPE_v9.4_SS3M.pptx.zip
AutoPIPE FAQ on-linecommunities.bentley.com/.../autopipe-faq.aspx
AutoPIPE New usercommunities.bentley.com/.../autopipe-new-user-guide.aspx
AutoPIPE Newsletterftp.bentley.com/.../Newsletter_CAE_April2010_4a.pdf
View upcoming training schedule:www.bentley.com/.../courses
Create service tickets online at:appsnet.bentley.com/.../addcall.aspx
Contact Us by phone:selectservices.bentley.com/.../phone (press Americas hyperlink to see phone tree menu)
Thanks for the feedback. I really appreciate that.
Thanks.
-Morgan-
Hi Mike!
Would you mind to elaborate on the additional attributes that a valve has?
Thanks in advance
Efraim
Hello Efraim,
Instead of rigid pipe attribute information:
There would be valve attribute information:
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group===================================================
