selecting support
Dear Sir/Ms,
What kind of support that I should add between 2 Y-pieces (vertical Y-pieces)? I tried to add some kinds of supports (guide, incline, spring, V-stop,...) and when I added those support it affected of stress to the other locations.
So could you please recommend to select a better support for this matter!
Thank you in advance for understanding.
Vanno
  • Hello Vanno,
    I do not have a clear understanding of your exactly what you are trying to model. Can you attach a drawing of the piping arrangment and how the support is to function when attached to the pipe? or provide a better description of your arrangement.
    Thanks for your time.
    Mike Dattilio
  • Dear Mike Dattilio,
    Here is the Y-pieces. This Y-piece will has maximum along Y-axis so I want to know that which type of support that I should use? (currently, I am using "Guide support")
    Thank you for understanding.
    With best regards,
    LOK Vanno
  • Hello Vanno,
    Now I understand.
    With regards to your question:
    Based on this question, you noticed the stresses change in a different part of the model when you add a support /restraint at this location (between the y-connections). That would appear to be correct.
    As you already know, making changes to or adding supports at any location in a model will ultimately change the stresses at some piping location(s) based on a given load case/combination, In AutoPIPE, with a given applied load you can evaluate the implications of what will happen to the model if a support is rigid/gapped, or added/removed.
    In your model, anyone would need a good understanding of how the model is moving under a given load case/combination, then resolve a support system and/or adjust the piping routing to add more piping flexibility in order to keep the stresses below the allowable's being applied. This is the best advise I can give you.
    Mike Dattilio
    Support Analyst
