I am trying to rename a segment so that instead of D it will be A for example. Does anyone know how to do this. I cannot figure it out.
You would like simply to rename the segment after D to show up as A (get sequence like D, A, H, B etc..) or get logical order A, B, C, D etc.
For segments re-order check under drop menu Edit > Segment > Reorder . In this dialog you can reorder segments, by typing in numbers in the Order column and clicking the Re-order button will Re-Name the segments. E.g. for 2 segments A and B which appear as order 1 and 2 respectively. To make segment A be B and vice versa, simply enter Seg A order = 3 or higher than Seg B order = 2. Clicking the Reorder button will re-sort the segment naming.
Answer Verified By: Mike Dattilio
Is it possible to simply rename the segments? I have two models and I want the first segment in my second model not to be named segment A, but segment F. Does this has to be done when you define the segments? For me it seems like it is too late to rename the segments once they are defined.
