The following recorded eSeminars from Bentley AutoPIPE and AutoPIPE Vessel are now available:
AutoPIPE Vessel Powered by Microprotol
Discover the Most Comprehensive , Flexible Software for Optimized Pressure Vessel, Heat Exchanger or Tank Design
44 minutes – Recorded September 26, 2013
AutoPIPE Vessel Powered by Microprotol delivers a fully automatic workflow including complete global codes and applied loadings for the design, construction and operation of pressure vessels, heat exchangers, tanks, and air coolers.
Discover greater productivity, safer designs, and cost effective manufacturing
Heat Exchanger Design in 10 Minutes
51 minutes - Recorded November 26, 2013
In this new eSeminar you will learn about important design and construction considerations for heat exchanger design. Discover the comprehensive solution that optimizes the process of heat exchanger design, improving modeling accuracy and efficiency, and reducing fabrication costs.
With AutoPIPE Vessel Powered by Microprotol, you can benefit from comprehensive features including:
AutoPIPE
More Efficient Pipe Stress Modeling with AutoPIPE
46 minutes – Recorded September 19, 2013
AutoPIPE is the most comprehensive piping analysis software for small to high-end piping projects worldwide. Providing superior quality assurance to ASME NQA-1, ISO 9001, and nuclear ASME III codes, the latest version of AutoPIPE now uniquely integrates with any major Plant CAD system through innovative new 3D hot clash detection functionality.
AutoPIPE surpasses other pipe stress tools with new productivity features including:
