Download from Bentley SELECTservices Online... click here
Download the ReadMe File... click here
Code Update EN 13445:2014 (European Design Code)
16.12.4 Design of Skirts with and without 0penings
16.12.5 Design of Anchor Bolts and Base Ring for Skirts
16.12.5 Design of Type 1 Base Ring for Skirts
16.12.5 Design of Type 2 Base Ring for Skirts16.12.5 Design of Type 3 Base Ring for Skirts
16.12.5 Design of Type 4 Base Ring for Skirts
22 Static Analyses of Tall Vertical Vessels on Skirts
Code Update PD 5500:2012+A3:2014 (British Design Code)
Design Against Elastic Instability
Full-faced Flanges with Soft Ring Type Gaskets
Flat Heat Exchanger Tubesheets Figures
Requirements for PWHT of Ferritic Steel Vessels
Inspection and Testing Changes
Demonstration of Design Acceptability by Stress Analysis
Flat End Covers
Annex G Changes
Recommendations for Arc Welded Tube to Tubeplate Joints
Example 4: Maximum Departure from Mean Circle using Chord Gauge
Copper Supplement
Copper Radiographic Techniques
Nickel Supplement
Code Update CODAP 2010 Revison 06/14
Section C1: Creep
Section C3: Flat Head Openings
Section C4: External Pressure = Internal Pressure
Section C5: 2.4.2 Maximum Allowable Diameter of 0pening
Section C5: 2.4.3 Internal Radius of Elliptic Head
Section C5: 2.4.4 More Specifications on Orientations of Welds on Nozzle Neck
Section C6
Section C7
Section C8
Section C9
Section C11
Code Update AD 2000-Merkblatter 2013 and 2014 edition (German Design Code)
AD 2000-Merkblatter 2013 and 2014 Edition
Code Update API 650 12th Edition Addendum 1, September 2014
API 650 12th Edition Updates
Code Update EN 13445-3
Calculation of Head with Offset Nozzle
Nozzles Close to Knuckle Region of Ellipsoidal Head
3.3.1 “Apply EN 13445-3 7.7.2 (P×2)” Enabled
3.3.1 “Apply EN 13445-3 7.7.2 (P×2)” Disabled
Internal Pressure At Least as Much As External
US formats ( A, B, C, D and E ) for 2D drawings
US Drawing Formats
Drawing Size Selection Dialog
Component Drawing Size Selection
View Manager Drawing Selection
