New Release – AutoPIPE Vessel Powered by Microprotol CONNECT Edition Update 7 (Version 40.07.00.007) is now Available. The Most Comprehensive Software for Vessel Pressure, Heat Exchanger, and Tank Design Optimization
Download from Bentley SELECTservices Online... click here
Download the ReadMe File... click here
To learn more about CONNECT features... click here
Material Database Update:
EN 12452;EN 458-2;EN 10025;EN 10028-3-4-5-6-7;EN 10207;EN 10216-3-5;EN 10217-7;EN 10222-3-4-5;EN 10269;EN 10272;EN 10273
EN Profile Tables
Euronorm 53-62; 19-57; 56-77; 24-62
CODAP C.9.9: Design of Leg support (new paragraph Ed. 06/14) without braces.
Local load analysis for skirt to compression ring (anchor) connection.
Added additional dimensioning sketches for TEMA types AKT / BKU Shell and Tube Heat Exchangers.
Corrosion value by chamber used as default value for corrosion.
Expansion joint design based on Finite Element Analysis (FEA)In accordance with TEMA 9th editionStress Linearization (ASME Sec. VIII, Div. 2, Part 5) Verification with ASME code allowable stressesAvailable on 64-bit OS only [ Technology Preview ]
Manage project level settings through CONNECT. [ Technology Preview ]
good design outpur for bellow design in term of SCL
PRAVIN
+919921160295
