AutoPIPE Vessel Critical Defect - Storage Tank design (API 650) input data in US units lead to calculation issues
A critical defect has been detected in AutoPIPE Vessel version 41.02.00.005.
When the input unit is US unit for storage tank design based on API 650 code, the report shows incorrect values of calculated thicknesses due to wrong unit conversion. See yellow highlighted below.
This issue has been fixed by correcting the conversion factor and will be available in the build 41.03.
