New Release – AutoPIPE Vessel 2023 Minor Update 1 (v44.00.01:2023-11) is now available.
New Release – AutoPIPE Vessel 2023 Minor Update 1 Powered by Microprotol (Version 44.00.01.014) is now Available. The Most Comprehensive Software for Pressure Vessel, Heat Exchanger, Air Cooler, and Tank Design Optimization
Download from Bentley ... click here
Download the ReadMe File... click here
To learn more about CONNECT features... click here
The following outline identifies new features and enhancements in the AutoPIPE Vessel 2023 Minor Update 1.
  • Defects
NOTE: Problems described below represent specific issues with specific test cases. It is difficult to succinctly describe a problem and how it impacted the specific test case. If you have any questions about the issues discussed in this report, please contact technical support.
    • Calculation / Report
      • #1286494: Flange with Clamped Bolts - Allowable Bolt Loads cannot be set by user.
      • #1292341: Earthquake EN 1998-1 - user-defined spectrum values are not correctly taken into account when a vertical spectrum is defined.
      • #1294580: Fixed Tubesheets HEX - The user-defined outlet chamber is replaced by a copy of the inlet chamber.
      • #1306151: GB 50011 (Chinese seismic code) - Vertical seismic actions are calculated but are not taken into account.
      • #1310352: ASCE 7-16 (Seismic Loads) : Clause 12.4.2.2 is not correctly applied (exception regarding vertical load).
      • #1308007: Sliding Saddle - issue with user-defined length of the oblong holes.
      • #1292266: Component Design - Local Loads EN 13445 - Shear load value used as radial and shear load.
      • #1292370: Component Design - Anchor : calculation crashes.
      • #1292579: Component Design - Local Loads EN 13445 - RF Pad allowable stress issue.
      • #1297045: ASME VIII Div.2 - Nozzles - Verification of Shell Diameter / Thickness Ratio not applicable on Heads.
      • #1293545: Report refers paragraphs which do not exist in CODAP 2010.
      • #1295282: Bundle Layout: when Impingement baffle is not connected with side plates, program crashes.
    • User Interface / Others
      • #1301870: Bundle Layout - The nozzle orientation reference change is not taken into account in the cross view.
      • #1316588: Limpet Coil - the starting level can no longer be 0 mm.
      • #1292380: Component Design - Anchor : Weight vs Mass (kg instead of daN).
      • #640272: The Stress User Values are not saved when Specific Gravity User value is entered too in the dialog box "Material".
      • #1283609: 2D Drawings - Anchor Double Ring represented a Single Bearing Ring.
      • #1286156: 2D Drawings - WN Nozzle Standard flanges - hub dimensions issue.
      • #1286180: 2D Drawings - Legs Cover Plate issues.
      • #1286442: 2D Drawings - Some saddle configurations are not covered with new parameters.
  • Security Release Notes
    • CVE-2023-45853 security vulnerability fixed.
