Is it possible to insert a second bracket support in AP Vessel, I am trying to insert brackets at the beginning and at the end of the vessel ?
Hello Eray,
Brackets would be used for a vertical vessel. It is possible to insert 0, 2, 3 or 4 brackets on a vessel. You can insert these by clicking on Insert>Supports and then selecting Brackets. The Support Properties dialog will pop up, where the Brackets can be defined by Quantity, Location, Orientation, etc.
Jessica Portuese
Bentley Systems, Inc.
Mechanical Application Engineer
