Hi
I'm using the AD2000-Merkblätter 11-2014 contruction code and PD 5500 2012 G2:09-2014 local load method.
I'm defining a nozzle without flange; projection: set in; internal: P=0
How can I configurate the pull penetration weld instead of fillet welds?
I've worked with the outward nozzle weld (1), outer nozzle weld (2) and inward nozzle weld (3) but the forces don't change.
Hello Kenneth,
AutoPIPE Vessel welds are only full penetration, can’t be defined as fillet welds.
Mike DattilioBentley Product Advantage Group AnalystAutoPIPE Product Line Bentley Systems, Inc.===================================================
