Section 12 of BS EN 13445-3 contains requirements for design of bolted domed ends, however Autopipe Vessel does not have any components which resemble bolted domed ends. Will this functionality ever be added to Autopipe Vessel?
Bolted domed ends are available with the floating heads for Heat Exchangers only (types “S” and “T”). We have logged your request in our system and once we have significant number of requests for the same, we may review the possibility of implementing it in the future.
I have the same problem too. Many of our clients require the installation of bolted domend ends on vessels. Given that the Autopipe vessel is an excellent program for the calculations of pressure vessels according to EN and AD standard it would be great to allow these types of calculations as well
I have same problem here, please add this functionallity as it is very commom in my sector.
I need to calculate Dished Covers With Bolting Flanges according to ASME MANDATORY APPENDIX 1 1-6. And also in AD 2000.
Versão de agosto de 2020 ainda não conta com esse elemento.
