In AutoPIPE Vessel nozzle design tab, how to edit the leg size of the weld on the outer side of the reinforcement pad(i.e. Weld Size-Outer nozzle weld)?
The option, Weld Size-Outer nozzle weld, meant to enter this value is never editable.
Request your help in this regards.
Those fields are enabled for the ASME design pressure code only.
It depends also of the reinforcement of the nozzle.
However, we found a defect that do not enabled this field.
It has been fixed and will be available within the incoming release AutoPIPE Vessel Connect Edition Update 6
