Hi,is it possible to use AutoPIPE Vessel 40.06.00.007 Connect Edition via Citrix?Thank you in advance.
Hello Giancarlo,
Each version of AutoPIPE Vessel is thoroughly tested on various Operating Systems, OS (Win 7, Win 10, etc..). Recommend to review the read-me or "readme_autopipe.htm" file to see what OS a particular version of AutoPIPE Vessel has been tested on.
This does not mean that the software cannot be run on another operating systems not specified in the readme file, but that it has not been tested/certified by the development team to be installed on another OS. The user can try to install the application on any OS that does not violate the License agreement. However, Bentley cannot be held liable for results or provide technical support for installation of AutoPIPE on untested systems.
If you do encounter an issue with the program that is install on an untested OS, please log a service ticket providing system details, screen shots, and a brief account of the problems encountered. The development team is always trying to improve new versions of the application for our users. However, in most cases, the development team will not make any modifications to older AutoPIPE versions that people are trying to install on a newer OS not listed in respective version read-me file.
Mike DattilioBentley Systems Design AnalystDesign Engineering Analysis group
Thank you for your answer, but I would like to know if AutoPipe Vessel 40.06 works through Citrix.Thanks in advance.
