Dear All,
I am in trouble with a Spherically bolted head Calculation... Autopipe reports this 2 errors :
"356 FLANGE 14.02: gasket width insufficient ( minimum=31.104 mm ), the permissible gasket load is exceeded, use of a compression ring is recommended. 356 FLANGE 14.02: gasket width insufficient ( minimum=37.772 mm ), the permissible gasket load is exceeded, use of a compression ring is recommended."regarding the same non-maintained calculus condition.
I found it strange because these minimum widths are too big for this heat exchanger....
Does anyone knows where i can find this method of calculation ? I already searched in ASME Section VIII, Division 1 and Divion 2 but i did not find anything... It is strange that autopipe shows 2 errors with 2 different minimum gasket width, when on report only appear 1 condition not maintained. (see picture bellow)This error only occurs at "[in operation, Ext.P.]" condition ... And the values only differ in "(Hext)max" variable... Does anyone knows what it is "(Hext)max" ? I know what it is "Hext" and how calculate it, but i dont know the diference to "(Hext)max" ...
Can anyone help?
Take a look at our wikis on our error numbers. For this particular error I have posted the link below:
https://communities.bentley.com/products/pipe_stress_analysis/w/pipe_stress_analysis__wiki/48783/q-356-flange-xx-yy-gasket-width-insufficient-minimum-mm-the-permissible-gasket-load-is-exceeded-use-of-a-compression-ring-is-recommended
