1- Is it possible for the program to complete the Nomenclature drawing information in the config folder (C:\Users\Public\Documents\AutoPIPEVessel_version\Config\Nomenclature.dwg) based on the model created in the software?2- How does the program use this drawing?
1 - It is not possible for the program to complete the Nomenclature drawing information in the external file “Nomenclature.dwg”
But you can create a new block from this external file “Nomenclature.dwg” in the file “apacadmm.dwg” or “apacadin.dwg”.
File: “Nomenclature.dwg”
I changed all keywords ( added the character “|” at the beginning and the end )
From this external file “Nomenclature.dwg”, I created a new block “USERDEFINED” in the file “apacadmm.dwg”.
With the view manager, I inserted this new block “USERDEFINED” for a heat exchanger with a format “A0”.
Do not forget to move to production the file “apacadmm.dwg” to get the file “apacadmm.emsd”.
File: “aet ASME VIII div2.dwg”
After generating the 2D drawing in AutoPIPE Vessel, all the keywords have been modified
2 - How does the program use this drawing?
AutoPIPE Vessel does not use this drawing “Nomenclature.dwg”.
Read all “pdf” files in “View Manager\Drawing Customization” to use the view manager.
Start “AutoPIPE Vessel”
Menu “Help”
Menu “Contents…”
Menu “User Procedure How To”
Menu “View Manager\Drawing customization How To Topics”
Thank you very much for your comprehensive reply..
