Como adicionar bocal com tampo na parte superior do vaso de pressão, apenas existe a possibilidade de adicionar "boot" porem na parte inferior?
Have you seen our example vessel that are included with AutoPIPE Vessel? They are located at the following location:
C:\Users\Public\Documents\AutoPIPE Vessel_41\Examples\Vessel Example Models
We have a vertical vessel that has example configurations:
Vessel on legs ASME
Does this have the configuration that you are looking to model?
not this kind of model,he need creat a model like boot set in upper side of horizontal vessel
We also have the example vessel "column with head as transition"
thank u for your reply,but we can not create this model in horizontal vessel
Yes, is this what i want, but the software can't do.
