Não encontrei para calcular os trocadores multi tubos como mostrado no site e no help, onde consigo selecionar esse tipo de análise?
When you start a new project in AutoPIPE Vessel you can choose what type of vessel you are designing whether it be a standard pressure vessel or a shell and tube heat exchanger:
You will then be asked for the configuration of your heat exchanger which is based off of TEMA (tubular exchanger manufacturer association) standards:
These configurations will be specified by the process you are designing for. If you are not familiar with these configurations, then I would suggest you take our training on the subject at learn.bentley.com
Yes a know that, but I question about this type of the heat exchanger (MULTITUBE EXCHAGER). Look the image bellow.
