I followed the Help desription and added $1$, $3$ and $101$ codes to the header in report template files. Only $1$ shoes off in the report generated in AP Vessel.
What are special remarks I might have omited?
Hello
I don't know whether I completely understand your question... Modifying $1$ in the report is mainly to change the position, not the content.
If you want to add this info, yo has to modify the following fields:
If that wasn't your question please give me some more details of what you intend to do. Do not hesitate to create a SR with your emvd file and a screenshot of the final look you want to obtain.
Vivianne,
Thank you for your response and explanation on the primary school level.
No, this is not the case. The case is that I add keys to the file and they are not properly interpreted by the program, i.e. in the report I get "$101$" text instead of the content of marekd up by yourself fields. May it be the AP Vessel bug?
It is my understanding that $101$ itself is a symbol which should be exchanged with content, no matter of rtf document style etc.?
Best regards,
Maciej Rydlewicz, PhD Eng.
maciej.rydlewicz@softdesk.pl
+48 512206994
With so little info, it's hard to say. Without seeing your issue I have 2 possible answers: there is more than one $101$ or you have to type it again (erase the $101$ and write it all over). Rtf give problems if it's not done entirely once.
Thank you Viviane, Yes, RTF gave this problem this time regarding $101$.
