Fatigue analysis ASME VIII div2 2015 - error message for longitudinal weld : "This junction has not been maintained, choose another method."
Hello, I am trying to check the fatigue analysis (with ASME VIII Div 2 2015) on a vertical vessel 610mm outside diameter 6mm thickness with 6 bar internal pressure. Stainlesse steel 304
i have an error message for the longitudinal weld of the cylindric shell :
Do you know why ? and what can i do to check the longitudinal weld ?
