Is there any provision to model skirt access opening and nozzle opening separately in this software ?
Greetings,
This was posted in the wrong queue and has been moved. Please be sure that you are posting AutoPIPE Vessel questions in the correct location - here.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Unfortunately there is no separate nozzle opening provision available in software. But you can use vents & skirt access opening as nozzle openings.
If you want these two separately please reach out to AutoPIPE Vessel Idea Portal, raise your idea there. And depending on responses, we will try to incorporate this idea in upcoming versions of AutoPipe Vessel.
Regards, Tanaji Gaikwad
Senior Technical Support Engineer Bentley Systems Inc
