Reduction Factor
In the earthquake box, is the reduction factor input can be used to take into consideration of the following : EN1990 §5.1.3 - (3) When it is appropriate to consider dynamic actions as quasi-static, the dynamic parts may be considered either by including them in the static values or by applying equivalent dynamic amplification factors to the static actions.
