Autopipe Vessel EN13445
I get this output as a result of the calculations. Can you help me
  • Greetings,
    There can be several possibilities when you can face these errors.
    1. In case you create a file in older version and opened it in new version then there are chances of loss of material properties.
    2. Missed to assign proper material to components.
    3. Assigned material properties are not within the limit of design temperature.
    To avoid these please ensure you have assigned valid material and each component has allowable stress. See image below for reference,
    If you still face the error, please raise an service case and attach the model file (.emvd) so we can further investigate on it.
    You can raise a service case from here.
    Tanaji Gaikwad
    Senior Technical Support Engineer
    Bentley Systems Inc
