Release of AXSYS.Engine CONNECT Edition and AXSYS.Process CONNECT Edition
I am very happy to announce that both CONNECT Editions of Bentley AXSYS.Engine and Bentley AXSYS.Process are now available for Download on Select:
For both AXSYS.Engine and AXSYS.Process, the following enhancements have been made:
  • CONNECT Edition Features
–        Integration with CONNECT Client
–        Option to assign a CONNECT project in AXSYS.Admin
–        Bentley RSS feeds
  • Added support for Windows 8.1
  • Datasheet support added for Office 2013
  • Include the enabler for Bentley’s patching technology
  • Add support for ProjectWise CONNECT Edition
  • Add support for exporting from AXSYS.Engine/AXSYS.Process to ProjectWise for additional file types
  • Graphical Sheet view changes
–        The graphics windows now appear as tabs in the main window and can be split into two areas by dragging the sheet title bar.
–        This tab style can be disabled by setting SET AXSYSTABBEDDOCUMENTS = FALSE in your configuration file.
–        The graphics sheet toolbar has been moved from the side of the sheet to the main menu bar.
–        To draw a sheet either select it from the File->Open Sheet menu or select it in the Model Explorer or select it on the command line.
–        A new menu command File->New->Graphics Window allows you to view other sheets at the same time.
  • Window view changes
–        By default, the Model explorer and Data View are now displayed when AXSYS starts up.
–        This can be disabled from the startup by setting SET AXSYSSTARTDOCUMENTS = False in your configuration file.
–        The Model explorer, Data View, Input and Output windows can now be docked anywhere including as a set of tabs.
–        New menu commands under the View menu allow you to change the look and feel of AXSYS and the Input and Output Window options have been moved to the new -Toolbars and Docking- sub menu.
–        Customize options allows you to select large icons and/or have the text under the icon.
–        All window settings are remembered between sessions and can be reset from the Tools menu.
  • Menu Toolbar Changes
–        User Toolbar images can be bitmaps or icons.
–        The user toolbar item DESC attribute in a script file is used as a hint when the mouse hovers over the toolbar item.
–        The user menu bar items DESC attribute in a script file is used as a prompt in the status bar.
–        The ATTRIBUTE BUILT_IN_COMMAND is now supported in script files.
–        The first two user toolbars positions are remembered between sessions.
Additionally AXSYS.Process now supports VMG Sim 9.0 for both simulation import as well as the stream flash.
 The readme files can be found here:
For more information on the AXSYS products, please visit:
https://www.bentley.com/en/products/product-line/plant-design-software/bentley-axsysengine
https://www.bentley.com/en/products/product-line/plant-design-software/bentley-axsysprocess
Thank you to everyone who was involved in helping get these releases completed.
Best regards,
Tim Lawrence
