I am pleased to announce that the beta release of Plant Exporter is now available for download on Select.
Plant Exporter
Plant Exporter is an application that will connect to either i-model Composition Service for PDMx or i-model Composition Service for S3D to select the models to be converted from either PDMS/E3D or Smart 3D. Plant Exporter can be used for these conversions instead of setting up and running ProjectWise with Automation Services. The use of ProjectWise is still supported and requires the automation client from either service to be downloaded and installed with ProjectWise. The automation client is the 32-bit component of each service and the installers are also found on SELECT.
The readme file can be found here:
Plant Exporter Readme
Thank you to everyone who was involved in helping get this release completed.
Best regards,
Tim Lawrence
