OpenPlant CONNECT Edition Update 9 Release Announcement
On behalf of the OpenPlant team, it is my pleasure to announce the release of the OpenPlant CONNECT Edition Update 9 products listed below. These products are now available live on the Bentley Software Downloads site. Under Brand, you can select OpenPlant to see the following released products:
  • OpenPlant Modeler CONNECT Edition Update 9 (10.09.00.74)
  • OpenPlant PID CONNECT Edition Update 9 (10.09.00.74)
  • OpenPlant Isometrics Manager CONNECT Edition Update 9 (10.09.00.74)
  • OpenPlant Support Engineering CONNECT Edition Update 9 (10.09.00.74)
  • OpenPlant Orthographics Manager CONNECT Edition Update 9 (10.09.00.74)
  • OpenPlant Project Administrator CONNECT Edition Update 9 (10.09.00.74)
  • Bentley Raceway and Cable Management CONNECT Edition Update 9 (10.09.00.74)
OpenPlant CONNECT Update 9 also offers Data Manager as a cloud service which is now available as part of Collaborative Engineering Services in PlantSight. OpenPlant users can manage tags and data to ensure project information is trustworthy, actionable, and consistent. Seamless integration with OpenPlant can be leveraged to support distributed teams, utilize component-based workflows and manage changes for all your projects to have up-to-date engineering information.
Here are few of the highlights of OpenPlant CONNECT Edition 9 released products:
OpenPlant Modeler CONNECT Edition Update 9:
  • iTwin Workflows:
    • Ability to attach models directly from iModel in connected projects
    • New one way sync mode option to keep data in dgns but provide ability to push data into iModel. This setting can be applied at workset level
  • PlantSight Integration Workflow Updates:
    • Data Manager
    • Example Data Extensibility electron app
    • Ability to reference out other discipline data through volume-based reference out operations
  • Various piping component, symbology and modeling updates
  • Enhanced sample delivered workspace and worksets
  • Victaulic catalog updates
  • AutoPLANT to OpenPlant data import functionality
For further details please review the ReadMe file.
OpenPlant PID CONNECT Edition Update 9:
  • Batch link 2D and 3D tags in PlantSight
  • Save time inserting Assemblies by maintaining their original work breakdown property values
  • Page connectors now check PlantSight for next available sequence numbers
  • Unified KKS workspace implementation
  • External database query
  • Smarter tag editing gets the next available number when a change is made to a work breakdown structure property
OpenPlant Isometrics Manager CONNECT Edition Update 9:
  • Better representation of flanges for sloped pipeline
  • Improvement in presentation of dummy leg support data
  • Slope depiction as ratio
  • Visualization of Eccentricity
  • More control on slope output
  • Improved speed of DWG/DXF format Isometrics
  • Gasket dimension inclusion based on user setting
  • Enhanced logging mechanism for schema loading
  • Improved representation of detail sketches in output Isometrics
  • Additional processing and better Text representation for DWG/DXF output
OpenPlant Support Engineering CONNECT Edition Update 9:
  • Elbow lug, horizontal and vertical elbow trunnion supports have been added in new fitting attachment category
  • Templated for customized elbow lug and elbow trunnion have been added
  • Ability to place assemblies via locator
  • Ability to place weld lugs on curved shapes while matching curvature
  • Support of component based and PlantSight Integrated workflows from within OpenPlant Modeler
OpenPlant Orthogrpahics Manager CONNECT Edition Update 9:
  • Improved user interface for view definition functionality
  • Addition of supports chart interface
  • General usability and stability fixes
OpenPlant Project Administrator CONNECT Edition Update 9:
  • Tag Editor now works as Expression Editor for all properties and not just Tags
  • Option to copy existing workset files during custom workset creation
  • Updates for PlantSight Integrated workflows
    • Ability to add PlantSight only external properties
    • Interface to set PlantSight sync options
    • Provision to support iModel Bank
  • Flexibility to launch OpenPlant Specification Generator in ProjectWise Managed Environment
  • New tool to Update dataset for Bentley Raceway and Cable Management from previous version to latest version
Bentley Raceway and Cable Management CONNECT Edition Update 9:
  • Redesigned cable manager now features a ribbon menu with a superior user experience
  • AutoPlace conduit tool can now generate conduits that directly touch the raceway trays and ladders
  • OpenPlant Project Administrator can now perform dataset upgrade
  • Enhanced Raceway ID tool allows to quickly assign unique IDs to raceways without an existing ID
  • Ability to set cable voltage priorities
  • Schneider content now included in installer
  • Improved 3D cable performance
For more information about value of OpenPlant and the products in OpenPlant CONNECT Edition suite, please go to:
Abbas Ali Zaidi
