I want to import a lot of JSM files at one time using I-model composer, is this possible?
I have several hundred files and each file appears to have multiple i.dgn files. If I have to use I-model composer, as a step in viewing the model, is there a way to process all files at one time?
There is apparently no way to batch the process.
Answer Verified By: CADTech1
Thanks to confirm. I hope it was resolved and have no issues.
If there is still any concern you may always raise Service request for the same and post your queries. We will ensure faster response and try to get it resolved.
For more help on logging SR, kindly use below link.
How to Log or Report Service Request for Bentley Plant Products Product(s): OpenPlant Products Version(s): All Bentley Products Environment: GENERAL Area: N/A Subarea: N\A Overview How to log a SR informing of any problem… Last edited over 4 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
HTH
-Regards | Rahul Kumar
Rahul Kumar
