I am learning how to place pipe and components using Auto Plant V8i.
I am finding that the spec has to match the connecting component exactly or the component can not be placed-very fussy! For example, placing a flange with a spec that does not have the Facing or the End Condition of the connecting component exactly, cannot be placed. However, the catalogs I have do not contain the End Condition or the Facing that I need for the weld neck flange I am trying to place. Is there a way I can have Auto Plant use more generic criteria and not require specific matching details such as facing or End Condition to make placing piping and components faster and easier?
Hello Chuck,
The criteria is defined in Speckey.ini which is located in C:\Program Files (x86)\Bentley\Plant V8i\Modules\Base for Base module. Please see below.
I hope this helps.
Dinesh Solanki
Answer Verified By: CADTech1
