AUTO PLANT-JSM TO PXF FILE FORMAT
I am learning how to import/export equipment and piping models into/out of Auto Plant V8i using the Bentley tutorials on the Learn Server.
I have some JSM files from a client and realize now that I can not do much with these, especially in Auto Plant.  So can I convert an existing JSM file into a PXF file?
Parents Reply Children
  • Based on your initial question I am assuming you want to take the design represented in the JSM and do updates in AutoPLANT. If this is correct then unfortunately no, that cannot be done. JSM's can be used in the PlantSpace tools to run reports and generate isometrics. There was an older version of Bentley Navigator (8.6) that could view the JSM and do reviews.
    The JSM format was intended to be immutable and not extensible or usable by other products hence our move away from that to i-models.
    Answer Verified By: CADTech1
