I have a problem how to automatically integrate slipon flange (collar + loose flange) with bolts, nuts and gaskets when placing avalve (ball valve etc.) with flanges or wafer valve (butterfly valve or checkvalve for example). What are the settings must to have so that slip on flangewith bolts, nuts and gasket automatically appears to design? I know thatsetting AutoFlange must be set ON, so that flanges are coming to design. I havedone it like that but slip on flanges does not appear. Maybe it needs some modificationsin catalog where slip on flange exists?
I have got flanges with bolts, nuts and gaskets by using Lap Joint Stub End. My opinion is that it is not the right one when modeling loose flange with collar. At least loose flange looks very strange for me. In a picture below I have taken Lap Joint Stub End. After that I changed loose flange iwith PAINT software to show to show how this connection must exist.
This is how I want valves (etc.) with loose flanges with collar to look like:
One questions regarding collar for loose flange: howcan I get collar diameter connecting to pipe equal with pipe outside diameter. Diameter is now something strange (more than pipe OD) with decimals.How can I have butt weld mark between collar and pipe?
- Jukka -
Hello Jukka,
On Hub length graphics issue, I would like to inform you that this issue resulted in Defect Report# 210557, and will be evaluated by the product management team for our regular SELECT updates.
RegardsRahul Kumar
Rahul Kumar
Answer Verified By: Rahul Kumar
Hi, I am now using MiSt CE and I have a problem with text input method. What does this 3:0.5000 (red circled) mean? Where I can chenge input configuration so that I am able to input 3.5 (lie earlier)? This appears where text height is needed (dimension style, text editor etc.)
Please foward this if you are not the rigth person to answer (I tired to find a person from Bentley Communities to answer to my questoion but all was mentioned as "Cannot Message").
