Hello all,
Since 08.11.10.523 regular selection only selects the element you actually selected and you have to use the select parent command in the context menu to get the "old selection behavior" (or select pipeline/instrumentation loop/assembly).
Are a key-ins available for the "select parent" and similar commands?
Thank you in advance.
