Hi all,
Our workflow is to usually draft the P&ID's initially without any tags. Once the layout have been confirmed, the tag's are then applied.
Can someone please shed some light how this might be achieved?
Ben
Ben,
The prompt for the tag dialog can be disabled by selecting Settings>Drawing from the menu. In the P&ID Drawing dialog pick on the Settings tab and uncheck the Tag Dialog Prompt.
This will turn off the dialog prompting for a tag for all components. The number will still be created but it will be automatically allocated based on the tag format settings in the schema.
I hope this helps,
Tony DeRosa
Bentley Plant
Senior Consultant
