Horizontal and Vertical bends are only 24", 36" and 48". There are no 12" radius bends - used more than any other radius.
Mike, I just want to confirm that you still need to design with 12" radius fittings since these seem to be discontinued.
http://www.cooperindustries.com/content/dam/public/bline/Resources/Library/catalogs/cable_tray_systems/all_products/CT-13.pdf
12" fittings are still in the catalog that you reference see attached. I can check with our rep, but I don't believe that they would discontinue 12" radius since that is what is used must except when you have larger diameter cables that require larger bending radius. See page FTS-4. "Series 2,3,4 & 5 Fittings.
[V8i SS4 08.11.09.829, BRCM, Promis-e, OpenPlant Modeler, OpenPlant PID, STAAD, RAM, ProSteel, InRoads, FlowMaster, Map, PondPack, StormCAD, Descartes]
To add 12" bend radius to the fittings, please replace the files in your dataset(s) with the ones in this zip file.
Answer Verified By: Mike Francisco
